Antifreeze leak with pic
I've searched and to be honest I've probable read a thread that explains exactly what my problem is but I am kinda a noob at some of this stuff and I don't know for sure what I'm reading a lot of times. I took a pic of my leak and was hoping someone could tell me what part to replace.
I'm just guessing because in the picture , it just shows coolant on the steering box . So I would guess a hose or radiator leak . If its not a hose then try some radiator stop leak , I just bought a 79 ford f150 and the heater core was unhooked so I put the stop leak in and warmed the engine up and turned on the heater , it looked like I had a steam engine in the truck but it went right away within a couple minutes and I have not had any trouble yet .
You might want to check the radiator petcock, it may just need tightening (its located on the bottom driver side of the radiator). Also the driver side radiator tank (plastic part of radiator) will sometimes crack and leak. If this is the case you will either need to buy a new rad or take it to a shop that specializes in radiators to have it repaired. Stop leak nor epoxy will work for this. Lets us know what you find...
