IAC and identification
So I finally got to the IAC sensor today. Didn't really seem as though I did much. I sprayed it with carb/choke cleaner and put it back. I'm not sure if that plunger is supposed to move or not but it didn't budge. There also didn't appear to be a lot of sludge built up on it. The Haynes manual I have said replace the gasket, but there wasn't one. Should there be?
Also, while looking around, I found these two connections. Any idea what they go to?
By their size, number and location I'm guessing ABS connections. The larger red and black would go to the motor and the other for the module. They look like they connect on the top of the module.
Thanks Rusty, they have locked up twice and I skidded, but I assumed it was due to the severe ice condition at the time. Guess this is something I'll have to put on my "to do" list.
Thanks for the input, really appreciate it.
It didn't budge, it did spin, but no movement up/down, in/out. My manual also mentions something about measuring the one you take out as the depth of the new one should be the same. I didn't see where this one would adjust any. Should it?
