injectors not firing, will not start
Old 12-05-2009, 05:20 PM
wayland's Avatar
wayland is on a distinguished road
Default injectors not firing, will not start
My lady friend asked me to help her with her Blazer 4.3 it was quitting her several different times. I found a bad egr and changed it out. When I went to test the Blazer it died on me. Now it will not start. I am not getting fuel to the plugs. What I have done. checked fuel pressure 60, changed control module in dist. installed new coil, checked all fuses, installed another computer. I changed her plugs and put in a new fuel filter.
What am I missing. Something tells the injectors to fire. Could the egr I installed be bad causing this? Thanks for any help.
Old 12-09-2009, 10:40 AM
wayland's Avatar
Default Found my problem
This might help you if you are having the same problems.
There are 2 wires coming out of the front of your intake. Mine was red and brown, These wires go to the injector hookup under the intake. The Chevy 4.3 has the injector in a bad place under the intake. My problem was the injector wire was pulled out of the injector plug hookup. A $18 dollar part and my Blazer runs great now.
Old 12-09-2009, 12:38 PM
86Blazer327's Avatar
86Blazer327 is an unknown quantity at this point
Not the EGR.
ECM tells the injectors to fire.
Do you have spark?
Martin13
11-15-2013 07:32 AM
tylerbrewer
10-12-2011 08:18 PM
creighta
06-12-2010 02:02 PM
SSZ28
08-08-2009 11:37 PM
jhuseman
11-13-2006 09:30 PM
Quick Reply: injectors not firing, will not start
