Not getting gas.
Old Jun 21, 2011 | 02:26 PM
lealyn-toledo's Avatar
lealyn-toledo is on a distinguished road
Default Not getting gas.
I have a 1987 S-10 Blazer V-6, 2 wheel drive.It will not do anything but rough idle. Cant drive it, applying the gas pedal stalls it. The fuel pump is pumping fuel and I replaced the fuel filter. If I pour gas into the carberator(this truck has the early fuel injection so it looks like a carb!)the engine runs until the gas is used up. Can I take these injectors apart? I feel that this is the problem. Please help. thank you.
Old Jun 21, 2011 | 02:48 PM
Before you go tearing the TBI apart, test the fuel pressure. It needs to be 10-13psi for a throttle body injected engine.
Also, test the MAP & TPS sensors (links found using "map+sensor+voltage" & "tps+sensor+voltage" with a user search of "swartlkk" and apply to pretty much all GM TPS & MAP sensors regardless of year). If either of these are flaking out, they could cause a rough idle and overall poor engine operation.
You should also see if the EGR valve is closing off properly and check the engine timing (disconnect the timing connector first).
Old Jun 23, 2011 | 03:41 PM
Talking found trouble
map sensor was not the problem, removed fuel pump and found 2" rubber tubing @ the pump with a large hole in it, this car sat for years so tube rotted away. this tubing is installed @ the plant and is very pricey 20$ a foot. Auto zone didnt have it but the Napa dealer could order. thanks for the help
Old Jun 24, 2011 | 02:03 PM
JustJerry's Avatar
JustJerry is on a distinguished road
If the fuel pump has been in there for years, as hard as it is to change, I would replace it with a new fuel pump.
Old Jun 24, 2011 | 02:43 PM
Smile running
got the truck back together no problem, runs great probably because I went over all the vacum lines and fixed all the bad ones..thanks again for the help
Old Jun 24, 2011 | 02:44 PM
Glad you got it all back together!!
bagged02
May 23, 2012 09:01 PM
BigNick357
Apr 17, 2012 07:43 PM
JerryB52
Jul 13, 2011 06:35 AM
lealyn-toledo
Jun 21, 2011 03:10 PM
raymondabryan
Jan 7, 2010 07:15 PM
