1984 chevy blazer 4x4 2.8 6 cyl
Old Apr 30, 2010 | 01:08 AM
Elvis Percy's Avatar
Elvis Percy is on a distinguished road
Thumbs up 1984 chevy blazer 4x4 2.8 6 cyl
I have a transmission problem the housing bolts were loose the shaking and vibration would leave but while driving they would come back loose causing the shaking vibrations again what can be done to solve this problem? can i have a solution to my problem i don't work on car often but i can change a part. Also there is a noise that accompany this problem it also leave and return with the shaking and vibrations.
Last edited by Elvis Percy; Apr 30, 2010 at 01:23 AM. Reason: To add the noise to the problem
Old Apr 30, 2010 | 05:06 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Something else is causing this problem. I'd check for loose torque converter bolts, broken or cracked flexplate (flywheel), U-joints or a broken transmission mount. That's assuming you have a automatic.
Old Apr 30, 2010 | 12:54 PM
ohsofly's Avatar
I second the tourque convertor bolts or cracked flexplate. My wife has a 94 explorer that does the noise and shaking thing. Its been parked since christmas cause I dont feel like repairing it yet. Her truck has a broken flexplate in it from her throwing it into reverse without completely stopping (I make sure she doesnt do that on MY blazer). I would take a look at that possibility. When you rev that engine it makes a very loud whirring/screeching noise and the vibrations are bad at idle and unbeleiveable at more than 1000rpms. Im not looking forward to this job as I have to move the exhaust pipes to get that tranny out and the tranny is a massive heavy bugger.
Old Apr 30, 2010 | 10:13 PM
ohsofly,
Nice to hear from you again. Yes this is definately something broke and it ain't gonna fix itself. Loose TC bolts would be a blessing. If they are you need to remove a few of them as if they have been running that way a while it'll make the holes oblong. I think there are a second set ofholes that line up (at least in my old 82 Chevy 1/2 ton there were. Of course if the flexplate's cracked it's just a matter of time before it may shatter. Not pretty!
Old Apr 30, 2010 | 10:24 PM
Thanks for your response your insight has been most helpful, I have been under there tighting bolts,checking the mounts and I plan to be at it early I will let you know if everything went well. Thanks again!!!
Old Jun 10, 2010 | 01:34 AM
SldAxl85's Avatar
SldAxl85 is on a distinguished road
use lock-tite... same prob on my 78 gmc rig i take to Moab
melstal
Mar 24, 2014 05:13 PM
Russel Panke
Dec 31, 2012 01:12 PM
Duanerudin101
Oct 7, 2011 09:12 PM
mxpxpunkrock1987
Aug 13, 2011 09:07 PM
mxpxpunkrock1987
18
Mar 23, 2011 07:34 PM
