1987 s10 v6 2.8 attitude problem!!! PLEASE HELP!!!
Old Dec 17, 2011 | 11:00 PM
showteam2008's Avatar
showteam2008 is on a distinguished road
Default 1987 s10 v6 2.8 attitude problem!!! PLEASE HELP!!!
So bought a 1987 chevy blazer s-10 v6 2.8. the first night i drove it home it ran fine. the next morning it wouldn't start. I took it to the shop and they said it was the fuel pump. they changed the pump and it starts but now when it idles, it skips kinda like when the timing is off and the engine like blinks when it skips. when i press the gas pedal it goes as if it wants to cut off(and does 50% of the time). I changed the coolant temp sensor, and the ecm. the funny thing is it does it 80% of the time and sometimes it works as if it doesn't have any problems.
Old Dec 18, 2011 | 05:28 AM
neo71665's Avatar
Was it throwing any codes? Sounds to me more like an ignition mod going bad and they just jumped on the fuel pump bandwagon without knowing that was actually bad or not.
Old Dec 18, 2011 | 07:21 AM
nope, no codes but i can say that the ignition doesn't look original. it doesn't have the little wing looking things sticking out of the hole. idk if that matters or not but ill try and change that today
Old Dec 18, 2011 | 07:23 AM
chris015's Avatar
did they install a ac delco or delphi pump? these suckers are picky. if they put in an airtek then god help you.
Old Dec 18, 2011 | 11:21 AM
neo71665's Avatar
Not talking about the crank. Its in the dizzy under the cap. The things are bad about going out and it controls spark and fuel pulse to the injectors.
Old Dec 18, 2011 | 11:24 AM
so the distributor cap or the ignition module?
i just diagnosed the truck and got a code 34. MAP Sensor Circuit Signal Voltage Low (High Vacuum) how do i fix this?
Last edited by swartlkk; Dec 19, 2011 at 06:42 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 18, 2011 | 09:15 PM
neo71665's Avatar
Replace the map sensor, they go bad.
The ignition module is under the cap in the distributer.
Looks something like
Old Dec 18, 2011 | 09:29 PM
ok will do. I am uploading a video of my problem as well. this one isnt mines just a 305 that i saw on youtube and mines has a slight hesitation when spitting Chevy Caprice 305 TBI Fuel pump AC Delco EP375.avi - YouTube.
when i push the gas it wants to cut off.
this is mines - 1987 chevy blazer 2.8 v6 tbi fuel problems - YouTube
and this is some random dudes on youtube. Chevy Caprice 305 TBI Fuel pump AC Delco EP375.avi - YouTube
Last edited by swartlkk; Dec 19, 2011 at 06:43 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Jun 8, 2012 | 05:59 AM
Spiritcool's Avatar
Spiritcool is on a distinguished road
Default Airflow/Fuel Prob
As far as your dashboard lights, the blinking light SHOULD show a code, however I've never seen that. Also, your gas guage is at empty.....hmmm.
Furthermore, if you just bought this vehicle, how long has it had "old gas" in it? Fuel is only good for about 4 - 5 months - - I also like the posts above...
That is all.
outlawrcbb
13
Apr 8, 2011 09:00 PM
andrew_as
Apr 14, 2010 02:32 PM
wesmagyar
Jan 24, 2008 10:28 PM
pablo4429
Dec 22, 2007 09:59 PM
