1989 blazer 4.3 tbi crank no start
Old Mar 21, 2024 | 08:14 AM
Money_pit_blazer89's Avatar
Money_pit_blazer89 is on a distinguished road
Default 1989 blazer 4.3 tbi crank no start
ok ive done some mechanic work but not enough obviously to get my blazer running so be kind please and explain fully on what needs to be done. so my blazer has been sitting for multiple years probably like 4 most likely 4 years i went to put a battery in it and cranks but wont start so i thought it was the fuel pump changed that put a new fuel filter in as well and still no luck but it runs when i spray starting fluid on it unitl that runs out i hear from different sources its the distributor or the ignition control module but i plan on running more tests on it tomorrow morning any suggestions on what to do thanks for the help in advance it is greatly appreciated
Old Mar 22, 2024 | 11:11 AM
mr.vls's Avatar
You need: Fuel, Spark, Compression, Timing.
If it runs with starting fluid you have spark and Timing and compression
Fuel:
1.Are the Injectors firing. A NOID Test Light can be used to verify that you have pulse to the injectors.
2. Are the injectors spraying fuel?
3. Fuel pressure correct. TBI likes 9-11 psi running.. There is no test port for TBI from the factory. Need to have a test gauge installed.
The easiest place to install a test gauge inline is at at the fuel line connection at the frame rail.
The TBI has a fuel pressure regulator internal to the TBI. You may have a faulty regulator.
The regulator consists of a spring and diaphragm
https://shop.advanceautoparts.com/p/...B&gclsrc=aw.ds
Charrisps6
Apr 4, 2020 12:24 PM
Justablazer22
Dec 2, 2019 02:53 AM
Love/hate relationship
May 6, 2013 08:30 PM
Emrick357
19
Oct 5, 2012 11:04 AM
bigal04
Feb 3, 2008 02:15 AM
