1990 Blazer differential compatibility
Old Nov 29, 2015 | 02:21 PM
surreybrad's Avatar
surreybrad will become famous soon enough
Default 1990 Blazer differential compatibility
I have a 1990 Blazer with a Dana 12 bolt rear. I want to install a complete rear diff with disc brakes and equally strong gears from a newer truck at the wreckers. Can anyone tell me where I can find a list of what will bolt on to my 1990 or with the least amount of conversion work. Thanks
Old Nov 29, 2015 | 06:30 PM
richphotos's Avatar
4wd or 2wd?
Old Nov 29, 2015 | 07:57 PM
surreybrad's Avatar
It's 4wd. It originally had a 10 bolt I think but the previous owner switched it to a 12 bolt from an earlier model.
Old Nov 29, 2015 | 10:54 PM
richphotos's Avatar
You can get a rear diff out of a second gen that has disc brakes. If you google that you will find a lot of info about it.
You will obviously need to make sure it matches your current gear ratio.
Just make sure you do not get a rear diff out of a zr2 as they are wider.
Old Nov 29, 2015 | 11:09 PM
surreybrad's Avatar
Ironically, I have a 1998 ZR2 and discovered the size difference on a hunch but forgot to consider the special aspects of the ZR2. This is good news because the one thing there isn't a shortage of around here are 2nd gen Blazers. Also, thanks for the heads up about the ratio and this timely response to my request for assistance.
ScarletIce
Jul 10, 2014 07:08 PM
Drew4711
Oct 6, 2012 12:47 PM
deadpool
Nov 10, 2009 01:45 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
EMTBlazer
Dec 3, 2006 07:13 PM
