1992 full size chevy blazer stiff gas pedal
Old May 16, 2011 | 06:26 PM
Murder after Midnight's Avatar
Murder after Midnight is on a distinguished road
Default 1992 full size chevy blazer stiff gas pedal
The pedal is stiff, the accelarator cable and transmission kick down cable has been changed. Any ideas what this could be? I cleaned cleaning the throttle body but this did not seem to help.......any ideas?
Old May 16, 2011 | 08:10 PM
How difficult does the throttle shaft turn without anything connected?
Old May 16, 2011 | 08:39 PM
hmmmmm....i will have to check.....you mean the butterfly shaft in ide the throttle body?
Old May 16, 2011 | 09:34 PM
Yes. If the shaft turns hard, you may have to pull the throttle body and remove the throttle plates and the shaft to clean it up.
Old May 19, 2011 | 01:24 AM
chris015's Avatar
I may be wrong,isnt there little brass bushings that need to be replaced in the throttle body?
I noticed his is a old blazer,If its carbureted im probably wrong.
Old May 19, 2011 | 06:54 AM
I can't say as I have ever pulled apart a TBI throttle shaft, but the older ones do not have bushings. The lower throttle plate on the q-jets is typically bored out for bushings after the holes wear out, but they don't come that way stock.
Lippyp
Mar 6, 2011 01:24 PM
goerzenl
Nov 1, 2010 10:14 PM
Kendo
Sep 24, 2009 01:12 AM
05box
Apr 23, 2008 07:25 PM
Chevy Lover
Aug 2, 2007 11:06 AM
