1992 Two Door 4x4, serious issues :(
#31
It is, the leak is only like 6 to 8 inches upstream.
So that looks like my big option here. Finding a way to plug it up entirely.
My issue is, that I'm not sure of a way that's relatively cheap, and isn't just glue on the wound. I'm not sure of price on the straight up weld, because it seems like it would need a new pipe there, and it's directly, literally, directly after the collector. Practically on the collector. I'll talk to my guy tomorrow.
#32
Is your exhaust leak before your o2? If so then it would be showing a constant lean condition which the computer would try to make up with by raising the long term ft into a rich command, but once it's out of fuel control it would show a code for o2 constant lean condition. After that it's just going to be in limp in mode. So if it is before the oxygen sensor then you need to get it fully plugged up.
![Icon Stooge](https://blazerforum.com/forum/images/smilies/icon_stooge.gif)
& the FT Newbie is talking about is the Fuel Trim.... nothing we can manage unless you're gifted/smart & plugged into the computer as it runs. As in when I get mine dyno tuned, he has his laptop plugged into my OBDII port & is reading & changing the PCM.
#33
There is a muffler/exhaust bandage in stores. It IS a bandage in all means. There's a length of aluminum or tin & some sealant, scuff/clean the area, apply the sealant around it, wrap the area with the tin & strap it at both ends with the supplied hose clamps. Drive for a while etc to cure the sealant & it's sealed - for a few months. Also there are fabric bandages.
In the meantime go to a wrecker with a cordless sawzall etc & look for a blazer that has the collector you need. Cut the bolts (try a socket but GL) & as far as you can along the pipe & take that to a shop to have it expanded at the non collector end to fit over your existing exhaust pipe. IF that existing pipe is in decent enough condition to be welded, they or you could just clamp it using an exhaust clamp.
#35
Hopefully all the talk & babble has & will help correct things for ya.
GL!
Just thinking outloud often helps... as if your listening to a friend talk about things/issues. A 3rd party point of view.
GL!
#36
Well... I'm still pulling a code 44. The exhaust is all plugged up, as well. I'm going to go hit the local bob karls to see if I can't find a new to me set of collector/y pipes anyway, to keep from a leak reoccurring, but I don't know where to look next. I reset my ecmb, then I pulled my neg battery wire to reset everything, just in case the computer was doing something weird with my fuel.
Now, the only thing I can think of would be if my injectors needed cleaned, or something's up with my fuel lines, I'm lost again, lol. No code 13 anymore, still, just the 44.
travisrussell88
07-06-2010 07:46 AM
GMdesigner
10-04-2007 01:55 PM
