1993 4.3 cpi fuel pressure issue help please
Old 07-21-2013, 11:22 AM
cammed93's Avatar
cammed93 is on a distinguished road
Default 1993 4.3 cpi fuel pressure issue help please
Ok so I've been trying to solve this problem for about 2 weeks now nothing is working I turn the key on and the fuel pressure gauge reads 60psi until the pump shuts off then bleeds down to zero spider injection system replaced nut kit replaced fuel filter replaced and I bought a whole new sending unit with new fuel pump on it all replaced within the last two weeks really frustrating any help is appreciated
Old 07-21-2013, 11:36 AM
cleburne red's Avatar
So when you hit the key, it shows 60, but as soon as the pump shuts off (2 seconds or so) it bleeds back down to zero? There is a leak somewhere. What brand of parts did you use? New, used, or rebuilt?
You need to isolate the fuel pump and test the pressure there. That will determine if the problem is in the pump, or in the injectors. You will need to modify the pressure test rig so that the fuel pump dead ends at the gauge. You might have to run to home depot for some fittings. I ended up testing mine out of the truck, in a bucket of gasoline, because I couldn't get a good connection with it in the gas tank. You could also put the gauge on the end of the fuel filter, as well, if that makes it easier.
If the pressure holds there, the problem is in the injectors/regulator. If it still won't hold pressure, the pump is bad.
There's a metric butt-load of threads about this on here! Do some searching on here, figure out where the problem is. It's not voodoo, it's just a blazer! LOL
Old 07-21-2013, 12:54 PM
cammed93's Avatar
I pulled my injection system off plugged the end of my main line and put my pressure gauge on key on went to 60 and held so I went and got another injection system and put it on and same thing bled out
Old 07-21-2013, 01:33 PM
cammed93's Avatar
All parts are new
Old 07-22-2013, 07:21 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
you must have got a defective regulator or injector in the assembly.
Old 07-22-2013, 09:08 PM
That's what I would think. If you isolated the pump from the injector, and it held pressure, it would have to be in the injector or regulator.
Old 07-23-2013, 07:56 AM
make sure connections are all good and no o-rings got doubled up
Old 07-23-2013, 11:29 AM
cammed93's Avatar
Ok so to check the injection system I took the return line off of my sending unit plugged it and it held pressure so Idk if my sending unit is somehow bad
Old 07-25-2013, 04:24 PM
cammed93's Avatar
Anyone have any ideas
Old 07-26-2013, 08:58 PM
94s10blazin's Avatar
94s10blazin is on a distinguished road
if you plugged return line and no leaks and pressure held for 10mins 50psi and up take the sending unit back and try again , double check oring on fuel line to injectors can be tricky and PITA.
Quick Reply: 1993 4.3 cpi fuel pressure issue help please
