1993 4.3L vortec vin"W" 4x4- Coolent Leak!
Old Jan 16, 2009 | 11:38 AM
redskins1's Avatar
redskins1 is an unknown quantity at this point
Default 1993 4.3L vortec vin"W" 4x4- Coolent Leak!
My 93 S10 Blazer, 4 door, 4x4 4.3L Vortec vin "W" is leaking coolent from somewere under the area of the distributor. I can't pinpoint the exact area.
From above, I don't see anything. From below it is leaking down on the drivers side of the oil pan. The leak is fairly significant. It is not either of the freeze plugs. I have not found a digram of the cooling system anywhere. I have the Haynes repair manual but can't find anything! Any help would be greatly appreciated! THANKS!
Old Jan 16, 2009 | 01:25 PM
rriddle3's Avatar
Default RE: 1993 4.3L vortec vin"W" 4x4- Coolent Leak!
If you take a flashlight and a mechanics mirror and look at theupper rear of the engine, you will probably find that it is leaking from the intake manifold gasket.
Old Jan 16, 2009 | 01:29 PM
My thoughts exactly!
Old Jan 17, 2009 | 09:06 AM
redskins1's Avatar
THANK YOU! That is exactly where it is leaking from. Much smaller hole than I thought, maybe the size of a pin.
Now, would it make more sense to replace the gaskets or try one of these "Chemical" sealent products for the cooling system?
Again, THANKS rridle3 and swartlkk!!
Old Jan 17, 2009 | 11:28 AM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Don't know what Kyle and Rick think but I don't know how comfortable I would be with stop leak in it. Depends on your budget and travel that you do-ie how far from a tow truck are you at any given time! Jerry
Old Jan 17, 2009 | 12:09 PM
redskins1's Avatar
Thanks for your input Jerry!
Any idea how long it would take to change the intake manifold gaskets?
Old Jan 17, 2009 | 01:24 PM
Depends upon how skilled you are-or whomever you have do it. Lastly...how many problems you have with the truck when done ! The good book probably says 4-5 hours. Jerry[&:]
Old Jan 17, 2009 | 02:09 PM
Definitely replace the gaskets!
Old Jan 17, 2009 | 03:06 PM
redskins1's Avatar
again guys, thank you!
wish me luck. I am going to replace the gaskets myself.
I'll keep you posted.
thanks.
Old Jan 17, 2009 | 07:09 PM
you're welcome and...............................go Cardinals!!!![&:]jerry
