1993 blazer no heat in vents
i have 1993 chevy blazer s10 i changed the heater core ,radiator, thermostat,fan cluch it heats up but no hot air out of vents same with air conditioner i checked all doors and the open when needed i dont know whats next can some one help thank you chevyblazer4x4man
Check behind the glove box door. There is an arm the goes to the vent door for heat, when you rotate the heat control **** the arm should move if not then you may have a problem with the arm, motor or connections to the motor moving the door.
msfan324
10-19-2012 02:27 PM
mdkuni
10-07-2008 10:01 AM
SnowRemorse
09-08-2008 07:30 PM
yackel
02-12-2008 06:14 AM
clone432
02-01-2007 11:29 PM
