1993 Chevy s10 blazer 4.3L cranks but won’t start!
Old Sep 6, 2018 | 01:30 PM
Matt Evan Cinquini's Avatar
Matt Evan Cinquini is on a distinguished road
Default 1993 Chevy s10 blazer 4.3L cranks but won’t start!
I recently did a complete tune up by replacing all plugs, wires and replaced the cap and rotor for the distributor. I also did an oil change and replaced the air filter. Once I completed everything, I cranked it up and it started but it was horribly off time. So I redid all the wires and tried again but no difference. Still ran off time. Messed around with the cap and rotor, and still couldn’t see why it was running off time. So I drove it home, with it running off time, and parked it. A few days later I tried starting it and it wouldn’t start. Only cranked. Fuel pump is kicking on, and I replaced the distributor coil and also replaced the vacuum check valve and some vacuum hoses that were connected to it cause some of them broke off. Still won’t start. I even tried the old screwdriver in the spark plug boot method, and from what I saw was a spark. So I’m stuck right now and I really want to get this thing running. Could the engine be off time and need to be retimed?
Old Sep 6, 2018 | 02:48 PM
When you say you did the spark plug wires, did you replace them one at a time so to not mix them up? How did you check that they are correctly wired when you checked them? Did you take the distributor cap off and inspect the rotor? Was there any suspicious wear? If you have the old rotor and cap you might put them back on to see if the problem is with them.
I've read that not using AC Delco parts for the cap and rotor can be bad. What brands did you use?
Old Sep 6, 2018 | 06:32 PM
I did everything at once, so all plugs and wires and the distributor cap and rotor were replaced at the same time. At first I did use bosch sparks plugs (bad idea, just didn’t have any good AC delcos in stock) but then I recently put AC delco rapid fires in it. Still didn’t start with those in. I know the plug wires, cap and rotor are all carquest brands. Got them from advance auto parts. I looked up the firing code for the engine I got and the wire diagram so I hooked them up to the diagrams I saw, and even put them on like how the old wires were. Now I can’t put the rotor back on cause it’s broke in the process of being taken off for being on there for so long. And the old cap was pretty burnt up. I also smell fuel every time i crank it
Old Sep 6, 2018 | 11:49 PM
Assuming that your problems are associated with the things you replaced, my best guess is that it is with the rotor and distributor cap. Of course this is assuming you had the wires routed correctly. I've seen pictures of ill fitting rotors that hit the inside of the cap. I would suggest getting an AC Delco cap and rotor set. Then see what happens.
P.S. I am fully aware of what can happen when one "assumes" something! If anyone else has any ideas, please chime in and help this person.
swanman35
May 11, 2013 04:40 PM
Klturi421
Aug 25, 2012 09:30 PM
tony022
Jan 18, 2012 07:13 AM
86Blazer4x4
Jul 16, 2009 02:36 PM
Charles808
Dec 16, 2006 10:18 PM
