1993 S-10 Blazer not starting
Old Jun 28, 2008 | 12:41 PM
Lanman's Avatar
Lanman is an unknown quantity at this point
Default 1993 S-10 Blazer not starting
I have a 93 S-10 Blazer. It has the 4.3L. It had been starting and running fine till last Friday. I wentto start it in the morning, and nothing. It did not click or anything. The battery is fine, i pulled it and had it tested. I thought it may be the P/N switch. changed it. Next guess was ignition switch. changed it. Next was the starter. (that was a pain to pull). It bench tested fine. I am running out of thing to try. It has almost a full tank of gas, and I do hear the pump kick on. I do not see any bad fuses. I am open to any help. Thanks in advance.
Old Jul 12, 2008 | 03:42 PM
Lanman's Avatar
Default RE: 1993 S-10 Blazer not starting
My truck is still not running. I had not worked on it in several days. I decided to warranty out the ignition switch. Thought I may had a bad one. Something strange happened. I pulled the two plugs, and as soon as I plugged in the new one, the radio came on. The key was not on, or even in. So there is power to it from somewhere. I was not ever grounded. The blazer still does no start. I did ground it, but but it is not mounted. Any ideas?
Old Jul 15, 2008 | 10:55 AM
94_SBlazer's Avatar
94_SBlazer is an unknown quantity at this point
check to see if you have spark and go from there.
Old May 28, 2009 | 11:00 AM
jdt's Avatar
jdt
jdt is on a distinguished road
check for burnt inline fuse to starter.
Old May 28, 2009 | 11:42 AM
oisinirish's Avatar
Wait. Still doesn't even "try" to turn over?
Old May 28, 2009 | 12:15 PM
Do this by removing the positive battery cable to the starter and pulling on it. If it stretches quite readily, the fusible link is toast.
freez
Nov 30, 2011 02:11 PM
jdcookjr
Feb 7, 2010 03:11 PM
Mo Lee
Oct 15, 2008 08:05 PM
Sprocket
Mar 20, 2008 09:39 PM
richard5294589
Dec 23, 2006 01:03 AM
