1993 s-10 v6 4.3 4wd- engine not starting
Old Feb 7, 2010 | 11:33 AM
jdcookjr's Avatar
jdcookjr is on a distinguished road
Default 1993 s-10 v6 4.3 4wd- engine not starting
I have a 1993 s-10 v6 4.3 4wd, i recently changed plugs, wires, cap, and rotor. after everthing was installed the engine would not run. it turns over, but will not attempt to even run. after a few times of triple checking the wire configuration, the results were the same. does anyone know what I could have done or is there just something out there that i missed?
Old Feb 7, 2010 | 11:45 AM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
did it run and start fine then before you did this?
Old Feb 7, 2010 | 12:47 PM
jdcookjr's Avatar
Default engine trouble
yeah it ran fine. yesterday morning I ran to autozone picked up the parts, came home changed them out, then ran into the problems
Old Feb 7, 2010 | 03:11 PM
Banned
check and make sure you didn't cross thread any of your spark plugs, saw that once on a ford explorer that had just 1 cross threaded that ran rougher then rough. make sure all your wires going back to your distributor are actually "snapped" on. you can push them on and they won't make actual contact. you can feel them click in when they are completly on. when you changed the rotor did you put it back in the same way as the one before.
freez
Nov 30, 2011 02:11 PM
Lanman
May 28, 2009 12:15 PM
Mo Lee
Oct 15, 2008 08:05 PM
Sprocket
Mar 20, 2008 09:39 PM
richard5294589
Dec 23, 2006 01:03 AM
