1993 s10 blazer 4.3 cpi 4x4 boggin down @ 3000 rpm
Old Oct 13, 2012 | 01:02 PM
fbaker25's Avatar
fbaker25 is on a distinguished road
Default 1993 s10 blazer 4.3 cpi 4x4 boggin down @ 3000 rpm
Hello, I need help bad... in drive or park she will get to 3000 and bog down
and backfire through the intake.
What I have done:
New egr, nut kit, spider cpi, fuel filter, fuel pump, o2 sensor, knock sensor, map sensor, tps,iac valve, verified fuel pressure, cut cat, new plugs, wires cap and roter...
Any ideas
Old Oct 16, 2012 | 09:15 PM
bam_9_9_9's Avatar
bam_9_9_9 is on a distinguished road
take the egr out again and verify that there is no carbon logded inside. even though its new there is still lots of carbon deposits inside the intake passages that can come loose again. get a new gasket one that has the screen in it. my auto zone has to order it so make sure you call them before taking it off. also when you have it off spray alot of carb cleaner inside the two holes. then start it up for a few seconds to disloge any more carbon. dont be alarmed when the engine races and is loud since there is a intake and exhaust leak when the egr is off.
Old Oct 17, 2012 | 06:02 AM
fbaker25's Avatar
I pulled the spider again, one of the poppets was leaking... I am going to clean the area up up and order a new one... It appeared to have a poor connection. I wonder if anything else could cause this since it was spraying.
Old Nov 15, 2019 | 03:41 PM
akjuicebox@yahoo.com's Avatar
akjuicebox@yahoo.com is on a distinguished road
Default temp sensor?
What I have done:
Any ideas
Temp sensor maybe?? In my 92 Silverado it was the same issue
techboy89
15
Dec 21, 2017 04:20 PM
9194 Bravada
Apr 9, 2017 11:48 PM
fbaker25
Oct 14, 2012 11:49 AM
DrunkFlyfisher
May 4, 2010 09:52 AM
eskylar!59
19
Dec 23, 2008 09:13 PM
