1993 s10 blazer 4.3 cpi 4x4 boggin down @ 3000 rpm
Old Oct 13, 2012 | 03:28 PM
fbaker25's Avatar
fbaker25 is on a distinguished road
Default 1993 s10 blazer 4.3 cpi 4x4 boggin down @ 3000 rpm
Hello, I need help bad... in drive or park she will get to 3000 and bog down
and backfire through the intake.
What I have done:
New egr, nut kit, spider cpi, fuel filter, fuel pump, o2 sensor, knock sensor, map sensor, tps,iac valve, verified fuel pressure, cut cat, new plugs, wires cap and roter...
Any ideas
Old Oct 13, 2012 | 06:43 PM
richphotos's Avatar
What brand did you use on those parts, specifically the spider assembly, wires, cap and rotor, and plugs?
Old Oct 14, 2012 | 10:15 AM
fbaker25's Avatar
The spider assembly was a gb reman, I expected the spider but had a good pressure
test. When i got the blazer it was not running and sat for a few years... so at first I was reluctant to buy a new oem spider but figured if the part i bought was bad I would return it and purchase a oem part if i could get it running. Most of the parts are delco including egr, sensors, sensor connectors, and plugs... The wires are delphi and the cap and rotor i bought at autozone... May be thier brand. Could it be the ignition? If it is the spider is there another way to test other than pressure since that is good? Or should i be looking for something other than bleed off or starting and running pressure? Thank you for you help, i am lost
Old Oct 14, 2012 | 10:45 AM
ohsofly's Avatar
Nah, its most likely fuel. Ignition would set off the engine light, fuel issues dont. Check the timing too.
Old Oct 14, 2012 | 11:49 AM
fbaker25's Avatar
Should i pull the spider? i will check the timing again... What should the fuel pressure be at throttle? I thought about the pump so i tested again but at turn key it is at 63, idles around 58 and rises slightly past 65 at full throttle. Would this suggest a fuel regulator or spider issue? pressurd holds exact... what's my next move... This blazer is in amazing condition..and i would love to get her on the road. Thanks for the reply
fbaker25
Nov 15, 2019 03:41 PM
1993 S10 BLAZER 4X4 CPI
Sep 16, 2012 11:28 AM
Aanenson
Feb 1, 2012 11:00 AM
TheMoneyPit
Feb 18, 2011 08:31 AM
budiblazer
Jun 21, 2006 10:01 PM
