1994 blazer running issue
its got the 4.3 cpi motor (not tbi) what happens is when cold it runs fine but once it reaches running temp it runs like crap and i think its leaning out the fuel to much cause it will stall after hesitating and sputtering. Tune up has been done i think 2 years ago and no i havent had the opportunity to pull the codes cause its been parked for a year and the scanner at work sucks. its got 215,xxx. I know you cant give me the exact answer but if someone had this problem a starting point would be great thanks guys
maby try taking the egr valve off and cleaning it. scrape with a screw driver not too hard but to knock off the carbon buildup around the holes. maby its just stuck open. and make sure the needle or plunger what ever you want to call it thats blocking one of the holes moves freely up and down. DONT spray carb cleaner or anything inside it. it could mess it up. just spray it on a rag or someting them wipe it off. scape off old gasket and replace with new. oh and before you put it back on, start it up for just a couple seconds to blow out any carbon chunks out of the holes in the intake.
well update, got a new battery in it fired right up even after sitting for a year. ran maybe 5 minutes and died. Checked for spark at the coil pack and no spark. I replaced the coil and still died today (o well out $20). So what im gonna look into tommorow at work is what signals the coil to fire, I think it uses a ignition control module which has been replaced once but maybe out again.
I suggest you at least pull the codes before you do anything. You can do so without a scanner by doing this
Assembly Line Data Link (ALDL) Information
well as of right now there actaully arent any codes, ive started it three times this week but no check engine light on. im gonna get the ignition control module warranted out and i found the rotor i think is broken so im gonna get another one and put it back together and see what happens
ksimpson
14
Oct 7, 2013 05:25 AM
Farmer01
Dec 11, 2012 04:34 PM
Jpcalhoun
May 29, 2011 12:49 PM
jman_08
Jun 22, 2008 12:54 PM
