1994 s10 Blazer 4x4
Old Nov 20, 2009 | 07:42 PM
blazer_boss's Avatar
blazer_boss is on a distinguished road
Default 1994 s10 Blazer 4x4
Hello.
I have myself a 94 s10 blazer 4.3L Vortec.. The problem I am having is when the engine is cold, it kinda miss fires and smells like raw fuel.. when i take off and the engine is still cold, it sputters and doesnt want to run right.. But when the engine reaches operating temperature.. it clears up and runs fine..
i just gave it a tune up about 2000 miles ago
-cap and rotor
-wires
-plugs
-oil
-oil filter
-air filter
-fuel filter
HELP ME NOW!!! plz
Old Nov 25, 2009 | 11:27 AM
94blueknight's Avatar
94blueknight is on a distinguished road
check the egr to see if it's getting clogged. if that doesnt fix it then i'd say take the upper half of the plenum off and check to see that there are no cracks in the nut kit (plastic fuel lines inside plenum) that are causing fuel leakage. then check to make sure the Fuel Pressure Regulator is all good. then check to make sure the spider injector lines are not leaking.
Old Nov 25, 2009 | 08:11 PM
tomwht's Avatar
tomwht is on a distinguished road
My 93 vin W had similar symptoms. After having a shop replace the electronic egr (to meet emission regs. a shop had to do this to meet the minimum repair amount so I could pass emission testing), I ordered a fuel regulator from Amazon. After removing the upper plenum, I saw fuel pooling under the "nut kit" and bought a nut kit from Schucks.
I had problems getting the Torx screw off the old nut kit, but a bolt extractor finally worked. Now, my truck purrs! It's so much nicer than than the old misfiring Blazer I once drove.
error_401
Feb 22, 2016 02:28 AM
Outsydr
Jun 26, 2011 11:17 PM
error_401
Jan 12, 2011 03:35 AM
error_401
Nov 13, 2008 12:12 PM
CrashPro993
Oct 26, 2007 02:52 PM
