1994 S10 Blazer 4x4 O2 Sensor help wanted..
Old Oct 25, 2007 | 12:47 PM
CrashPro993's Avatar
CrashPro993 is an unknown quantity at this point
Default 1994 S10 Blazer 4x4 O2 Sensor help wanted..
What should my resistance values be if my O2 sensor is working properly? I only found (1) 02 sensor also, is there more? Thanks for any help...
Nolan
Old Oct 25, 2007 | 02:11 PM
Default RE: 1994 S10 Blazer 4x4 O2 Sensor help wanted..
To properly diagnose an O2 sensor, you need to watch the sensor voltage (in mV) and the activity of that voltage (lean/rich cross counts). On older vehicles, an oscilliscope is the tool of choice for accurately seeing the operational characteristics of your O2 sensor.
And yes, you only have one(1) O2 sensor.
*EDIT* - *Moving to 1st Gen Tech*
No need to double post your question...
Old Oct 25, 2007 | 02:25 PM
thanks, ive seen several posts on here about emissions and the severity of removing them. I live in OKand there aren't any inspections much less emissions testing facilities.Is there a way to make or purchase an o2 sensor simulator for my vehicle. I see several out there for OBDII vehicles but none for OBDI? What type of reading is the ECM looking for? Is an O2 sensor a PTC/NTC type sensor? Thank your for your help.
p.s. sorry about the repost.
Old Oct 25, 2007 | 02:29 PM
Your O2 sensor isn't used for emissions monitoring. The PCM uses it to determine the proper rate at which to inject fuel into the engine. It has to stay if you want your truck to run efficiently.
Old Oct 25, 2007 | 03:00 PM
Sorry for the misunderstanding, I'm putting a full exhaust on my truck and Im wanting to eliminate the the cat and o2 sensor. Should have stated that, sorry for wasting your time.
Old Oct 25, 2007 | 04:34 PM
No time wasted at all. As I already stated, you cannot eliminate the upstream (well the only one in this case) O2 sensor and hope to have your engine run properly. The PCM uses the air/fuel ratio information from the O2 sensor to determine how much fuel to put in.
Also, it is still a federal crime to remove emissions equipment from a vehicle originally equiped with ones. Just an FYI so you are prepared...
Old Oct 25, 2007 | 07:07 PM
thegr81's Avatar
exactly removing emissions parts will really cost you big unless you are doing it for offroad only then it would have to be trailored to and from wherever you go.
Old Oct 26, 2007 | 02:52 PM
Thanks everyone, apreciate the help.
WayneMurray1
Jan 6, 2012 11:36 AM
Outsydr
Jun 26, 2011 11:17 PM
blazer_boss
Nov 25, 2009 08:11 PM
error_401
Nov 13, 2008 12:12 PM
