96 S10 Blazer transmission filter change TIPS WANTED!!
Old Jan 5, 2012 | 09:57 PM
WayneMurray1's Avatar
WayneMurray1 is on a distinguished road
Wink 96 S10 Blazer transmission filter change TIPS WANTED!!
Hi, I recently picked up this blazer and am receiving a DTC P0753. I am preparing to replace both (A,B) shift solenoids. While the transmission pan is off i figured I might as well replace the filter as well.
While reading up on these procedures, I have heard that a lot of people were having trouble removing the pan from the vehicle(A lot of talk about having to remove cross members and "Y" pipes??). I was just hoping that someone could clarify for me what the exact problems were and how to get around them. I have looked all around the pan and it seems to be clear, but would like to hear from someone that has actually done it. I plan on starting this little project in a few days and would just like to know any tips to making it easier.
Old Jan 5, 2012 | 11:35 PM
chris015's Avatar
if its close to the same as my 91' model,all you need to do is disconnect the trans mount and jack up the transmission tail a little.
Old Jan 6, 2012 | 11:36 AM
El_Beautor's Avatar
I did the exact same thing on my '96 4-door and didn't have to remove anything else. Its a little tight to get to some of the bolts, but its all possible without removing the crossmember or the exhaust. I just had standard hand tools, although I did get to use my friend's hoist which made things tons easier. I think the 2-doors may be different but I'm not sure on that one.
LannyL81
Feb 27, 2012 11:58 AM
SlapBassist531
13
Feb 24, 2011 11:50 AM
boondoggle
Dec 15, 2010 08:36 PM
surferman08
Oct 15, 2009 10:59 AM
cimbali
May 28, 2006 08:59 PM
