1994 S10 Blazer front bumper bolts
Old Nov 12, 2009 | 01:15 PM
drummerdude's Avatar
drummerdude is on a distinguished road
Default 1994 S10 Blazer front bumper bolts
I have a brush guard I purchased used and I now want to mount it. It uses the lower front bumper mounting bolts, as well as a set of brackets back to the frame. Problem is I cannot figure out how to access the nuts on the back of the carrige bolts to remove them. How have you guys removed your front bumpers? I have found the bolts, but it is nearly impossible to get a wrench or anything up in there.Thanks
Old Nov 12, 2009 | 01:55 PM
neo71665's Avatar
ratchet wrench from the bottom. Take the grille out and the top is easy to get to.
Old Nov 12, 2009 | 06:36 PM
Blazin_Jason's Avatar
Ya remove the grille and then the bumper filler panel (7 10mm bolts). That should give you plenty of room to see what you're doing.
Old Nov 12, 2009 | 07:39 PM
neo71665's Avatar
94 won't have the filler like we got, one piece grille.
Old Nov 12, 2009 | 08:36 PM
The problem with removing the grille is not being able to replace the grille once the guard is installed. I have been able to get to the bolts from the underside of the vehicle. Reaching above the bracket and dropping the wrench down into the bracket. The issue is a regular socket isnt deep enough to clear the threads, but the deep socket is too deep to clear inside the bracket.
Old Nov 12, 2009 | 10:30 PM
neo71665's Avatar
Don't guess I've ever seen one you couldn't get the grille out with the guard in place. Is it homemade?
Old Nov 12, 2009 | 10:46 PM
it is not homemade. Its a Grizzle. I guess I will look into pulling the grille, mounting the guard, and then replacing the grille.
Old Nov 13, 2009 | 12:46 AM
That's what I did for mine.
Old Nov 13, 2009 | 09:11 PM
grille out, guard on, grille back on
hypertek
Jul 21, 2011 10:19 AM
1994BlazerS10
Mar 3, 2010 08:52 AM
94camaro
Dec 15, 2008 07:32 PM
blazerboy124
Nov 6, 2008 10:47 PM
Duntov
Apr 3, 2008 10:40 PM
