1st Gen eng. swap to 2nd Gen truck!
Old Mar 17, 2009 | 05:27 AM
bhawghead's Avatar
bhawghead is on a distinguished road
Default 1st Gen eng. swap to 2nd Gen truck!
Hey all, I'm new to your site, so a big hello from bowling green,ky. I have a tech. question for you? Me and my son;who is about to turn 16, have started collecting S-series blazers and trucks(he has fallin' in love with them), for his first ride he has chosen to build an 94' S-10, that had a 2.2L, we were contemplating putting a 4.3L from a 93' jimmy; my question is this since I have the donor vehicle to salvage my parts from. Is this a worthy father/son project or a waste of time,I mean will these parts interchange. I am thinking I may need different motor/trans. mounts, and driveshaft, but what about the rest. It is the 4.3 with the TBI, and 4L60 trans. Your input would be greatly appreciated, Thanks.
Old Mar 17, 2009 | 07:12 AM
Everything should swap over, but you may be in for a "fun" time. Wiring harnesses, etc will have to be swapped in as well. Is the 93 4.3L TBI or CPI?
Old Mar 17, 2009 | 09:08 AM
bhawghead's Avatar
The donor truck has a (4.3)TBI, I'm thinking just the wiring harness for the motor and the ecm is all I will have to change besides picking up the motor/tranny mounts and driveshaft from maybe a 2nd gen v6 model.
Old Mar 17, 2009 | 10:25 AM
I am not all that familiar with the 2.2L I4 used in the s-10s. Is it a multi-point setup (individual injectors for each cylinder)? If so, you will need to change the fuel system around. The fuel pressure demands of a MPI setup is a lot higher than what is required for a TBI setup.
Old Mar 18, 2009 | 04:18 AM
bhawghead's Avatar
I was wrong I believe this set-up is CPI, correct me if I am wrong. The 2.2 was a MPFI. So I will need to know what fuel pressure to run these at and if they are compatible.
Old Mar 18, 2009 | 07:36 AM
Yes, that is a CPI motor. And yes, the fuel pressure will be the same for the two. Hopefully the fuel pump can flow enough to support that engine.
drummerdude
Dec 28, 2011 09:29 PM
meego123
Dec 3, 2010 10:59 PM
NC93BLAZERLT
Nov 23, 2009 09:12 AM
old skool luvr
Nov 10, 2009 09:20 PM
rick nielsen
Engine & Internal
Oct 14, 2007 03:41 AM
