1st gen front hub nut torque spec
Old Apr 28, 2014 | 03:35 PM
yuka42's Avatar
yuka42 is on a distinguished road
Default 1st gen front hub nut torque spec
Can someone clear up what the torque spec is for the front hub nut? The big 36mm one. The chilton says 174 ft/lbs in one spot. And another spot it says tighten to 12 ft/lbs the loosen and hand tighten and install cotter pin. 174 seems like way too much. Help?
91 jimmy t-15 4x4 4door
Old Apr 28, 2014 | 07:45 PM
174ft-lbs would be for the 4wd trucks, but I seem to recall it officially being 180ft-lbs. It is lower on the 98+ trucks (and 97 trucks with integrated ABS sensors in the hubs) at 103ft-lbs.
12ft-lbs is to set the bearings on a 2wd front spindle.
rodmaker
Sep 12, 2014 10:47 AM
BlazerRaider
Jun 2, 2013 11:51 AM
benthm7
Jun 11, 2011 12:37 AM
myblackblazer
Mar 22, 2011 04:41 PM
2001Blazer4x4
Mar 2, 2005 10:45 PM
