2wd to 4wd Conversion
Old Jan 31, 2010 | 11:38 PM
NVANZEE's Avatar
Originally Posted by swartlkk
Well, the frames are different between the 2wd and 4wd so I would toss the idea of going with an IFS front end right out the window (which is why I mentioned a SFA swap). You would still need a transfer case and new driveshafts, but if you went with the NP231, there would be no electronics involved.
Oh, I didnt even think about that. So you would have to put a solid axle in it. IMO not really worth it unless your turning it into a trail truck.
Old Feb 1, 2010 | 05:22 AM
Kevin.N.Odom's Avatar
Kevin.N.Odom is on a distinguished road
I suppose I could keep the engines in them instead of swapping.. I'll keep everyone updated im going to look at it around 3 his afternoon
Old Feb 22, 2010 | 09:26 PM
rebelchevy's Avatar
rebelchevy is an unknown quantity at this point
if you consider sfa here is a lick to a site most of them do their own sfa swaps mostly in a weekend s10extremist.org
Old Feb 23, 2010 | 04:13 PM
neo71665's Avatar
Most guys (even over there) don't do their swaps in a weekend. It takes longer than that to get the steering and brake stuff lined out. Even if you know what you are doing with a SAS swap you take your time cause you are putting your life and the life of others in danger if something goes wrong cause it was a rushed job.
Old Mar 3, 2010 | 01:28 PM
madjay73's Avatar
madjay73 is on a distinguished road
Smile 2wd to 4wd conversion
as you were saying about having two blazers, I do have two of them an 85 2wd that i did a v8 conversion on and an 88 4wd with the 4.3L. as for the frames they are the same, the front suspension is what's different but it would be a lot better to just buy a 4wd it's not worth the money and time/trouble to convert from one to the other.
Old Mar 3, 2010 | 02:34 PM
I guess I didn't make the distinction in this thread like I have in others on this very topic. While the outer frame rails may be the same, the "frame" as one unit is not the same. If it were, you could swap over all of the (2 or 4)wd stuff to make it suit your needs. If it requires cutting/welding to swap brackets over, then the frames are different. Just want to be clear on the terminology. We do agree on the fact that it is more trouble than it is worth to convert. I think that is pretty universal.
Old Mar 4, 2010 | 07:48 AM
madjay73's Avatar
yes, this is true, like i said the front suspension is different and you would have to cut and modify the brackets on the frame to do this conversion. I was not trying to say you were completely wrong on this, just that to the naked eye the frames are the same. But as you mentioned there would be a lot of cutting/welding invalved, good checking up on me though. I should have been more clear on my earlier post.
hellrasin'
May 25, 2011 06:57 AM
Blazer_Man_Dan
Performance & Brainstorming
Mar 5, 2011 11:23 AM
theclothedcreature
Lifting Tech
Jan 22, 2010 01:37 PM
urone
Apr 15, 2008 03:52 AM
uneek
Nov 29, 2007 08:04 PM
