4.3 radiator help
Old Jun 7, 2009 | 03:37 PM
82 Iron Duke's Avatar
82 Iron Duke is on a distinguished road
Default 4.3 radiator help
Hello fellows, it never fails you fix something and something else breaks. Long story short, I just replaced the rad drain plug/**** and there is what looks a shaft underneath where the plug screws into. Is there supposed to be a hose attached or should there be a plug for there also?
Thanks, I have searched and found nothing.
Old Jun 7, 2009 | 04:21 PM
Answered in the older thread you posted in.
No, nothing is supposed to be connected. If coolant is coming out of the nipple, the valve is not closed all the way.
Old Jun 7, 2009 | 05:20 PM
Thanks again, I feel like a schmuck
Old Jun 7, 2009 | 07:03 PM
Thanks for all your help swartlkk, I appreciate it. Heres is one thing I was wondering about, the drain plug is plastic and it broke on the **** so the rest of the plug stayed inside the rad. I tried to remove it without having to take the rad out so it broke and fell inside the rad. It's not that big of a piece, do you think I could have any problems down the road with that piece being in the rad?
Old Jun 7, 2009 | 07:34 PM
It is likely that it would be sucked into the engine where it may cause problems with either the pump or the thermostat. If it were on the driver side of the radiator, I would say do not worry about it.
Old Jun 7, 2009 | 07:53 PM
It is on the drivers side, thanks, now I can sleep a little better.
Old Jun 7, 2009 | 09:15 PM
Drain plug on the driver side...?
Old Jun 8, 2009 | 07:10 PM
Yes, it's a 94 Bravada and the drain plug is infact on the drivers side. She ran fine today, no problems.
Old Jun 8, 2009 | 10:58 PM
Well, that would explain it.. No reference to what it was you were driving and I was just thinking of the later 2nd gens.
bigdaddykane93
Jan 4, 2010 12:03 PM
Ayieka
May 16, 2009 08:34 PM
afrench690
15
Apr 17, 2008 05:46 PM
Maldo15d
Dec 4, 2007 08:00 PM
Hanr3
Engine & Internal
Sep 8, 2006 02:31 AM
