4.3L/V8 bolt patterns
Old Sep 25, 2013 | 03:03 AM
925.89Blaze's Avatar
925.89Blaze is on a distinguished road
Default 4.3L/V8 bolt patterns
I have a 1991, 2wd, 4door, S10-Blazer with the first gen (NOT VORTEC) TBI 4.3L in it. Now like 98% of all these trucks i have the 700R4 behind it currently, and like 98% of all owner's of these trucks i wanna bolt in a 5 speed.
Now research says the NV3500 came factory, but i want something a lil cheaper and more abundant like a T-5.
1. So my issue is: Is the transmission/bell housing bolt pattern on the 4.3 block THE SAME as the early v8 block they were modeled after??
2. Will v8 bellhousings, and other trans parts bolt up to the block??
3. OR will a second gen T5 bolt up to the first gen motor??
Any and all info is greatly appreciated
Old Sep 25, 2013 | 09:08 AM
chris015's Avatar
Yes,they are the same bolt patterns.
The t-5 is weak,unless its the world class model which came on the camaros in the early 90s. A nv3500 came on these blazers stock,and will hold up to your 4.3 without a issue,ive seen a fair share of em at the pick it yard for less then 150 bucks.
Old Sep 26, 2013 | 01:10 PM
Talking
yes, a stock 4.3 But i plan on rebuilding it with'a a SC and nutty internals once i blow out the factory hardware. along with a posi 3.42-3.73 im estimating between 250-300HP
Now on another note, i know some second gen blazers, (mostly 4x4) came with t-5's bolted up. but is the vortec block the same bolt pattern the same as the first gen i have??
Old Sep 26, 2013 | 02:55 PM
chris015's Avatar
ALL 4.3s have the same bolt pattern.
If your gonna spend the money on the engine,spend the money on a t56 trans. you wont regret it!
Riggsy14
Tires and Wheels
May 3, 2013 03:46 PM
Bdub
Tires and Wheels
Nov 28, 2012 11:51 AM
helo
Dec 9, 2010 08:28 AM
Ellisx3
Jun 23, 2009 11:47 AM
