4wd problems
Old Dec 2, 2010 | 08:31 PM
355camaro's Avatar
355camaro is on a distinguished road
had a similar problem with my 94 ended up being a bad neutral safety switch.
Old Dec 4, 2010 | 12:12 PM
Green93's Avatar
Green93 is an unknown quantity at this point
yesterday i put a old tccm from a junk yard pretty rusty and dont really know it it works but when i plugged it in unhooked the battery and the fired it up the 4x4 did the same thing as before no change the tccm was defiantly clicking but still wouldn't take it out of 4hi but the hubs would still unlock but the transfer case wouldn't and the 4lo would still just flash for bout 30 seconds and then pop back into 4hi so idk what the hell it its and also when i put the transfer case motor on (encoder motor) the only way it would go on was when the transfer case was in 4hi so is that right or shouldn't the new motor be in the 2wd position? i thought it was spose to, please help getting sick of the freaking electronic 4wd crap. and where and what is the Neutral Safety Switch? as the previous post stated.
oh and when i press the 4hi button in any gear it will unlock the hubs and show on the switch it is in 2wd but yet the driveshaft turns when u role the truck in drive and you cant turn it in park or in drive with the parking brake on haha, and the hubs are in the unlocked position.
Last edited by swartlkk; Dec 4, 2010 at 01:59 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 4, 2010 | 02:49 PM
I have found that often it just doesn't pay to use junkyard parts. You really have to know that the part you are putting in is functioning properly to begin with for it to be a worthwhile diagnostic step.
Old Dec 4, 2010 | 08:03 PM
Green93's Avatar
when i did the jump on the codes plug in thing i got the code 1 witch i guess means a standby power fault or something but yet the thing i read said that the number one code comes up even if every thing is good but yet the transfer case is still engaged but yet the switch says its off so help me out please. thanks.
Old Dec 5, 2010 | 03:35 PM
If you recently had things disconnected, it may not have set any other code besides the one that states that things were recently disconnected.
Old Dec 5, 2010 | 08:18 PM
Green93's Avatar
well each time i tested the codes i unpluged the battery for about a minute, and does that new motor out of the box shouldn't it be in the 2wd position? because the motor would only go on if the transfer case was in the 4hi position so, got any ideas
Old Dec 5, 2010 | 08:30 PM
Don't unplug the battery if you want to have codes that mean something.
Nothing says that the motors should be in 2HI out of the box.
Old Dec 5, 2010 | 08:54 PM
Green93's Avatar
u have any idea what it would be cuz this is the second brand new motor that is doin the same thing so idk the transfer case is a 233c and the part they gave me is a Dorman 600-900 is that the right part for that. and i think it might be the tccm but it worked in 4lo before i had the new motor put on so idk freakin know at all. the part number on the old one is 54-20016 i guess. update i got another tccm from a junk yard that they say it works, gonna put it on tomarrow i would buy a new one but they have to special order it and costs $179.
Blazeme
Jan 24, 2015 06:08 PM
BearingEater
Jun 17, 2011 03:16 PM
2001 ZR2
Jan 16, 2010 12:39 PM
upblazer95
Apr 4, 2009 08:27 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
