4x4 and revearse issues (help?)
Old May 7, 2009 | 02:54 PM
94BlazerKid's Avatar
94BlazerKid is on a distinguished road
Default 4x4 and revearse issues (help?)
I just bought a 94 s10 blazer with 108k miles on it and it runs pretty well, the only problem is that when i am in revearse and hit the gas the truck starts to shake. Also, when i am in 4x4 and turn the wheel to the left, the front left tire seems to shake or rub against something and the truck shakes the same way it does in reverse (when in reverse it shakes if it is in 4x4 or not) Any ideas as to what could cause these issues? thanks.
Old May 7, 2009 | 02:57 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
sounds like something isnt dis-engaging and keeping ur front wheels locked together.
Old May 7, 2009 | 03:11 PM
i am able to coast in reverse without it shaking, its only when i hit the gas that it starts to shake
Old May 7, 2009 | 03:32 PM
I would check your motor mounts and trans mount first...
mikeinwi's Avatar
have you checked out ur cv's to see what kind of shape theyre in??
Old May 7, 2009 | 04:27 PM
im a begginer when it comes to this stuff but im trying to learn...what specifically should i be looking for that could be causing this problem? thanks.
Old May 10, 2009 | 07:32 AM
ok, i got it on a lift at my cousin's shop today and the front left axle is bad so i know i need that, also the u joint in the back, but i did grease the u joint and the shaking in revearse still happened...i think i may be looking at a shot rear end...how much would a new rear end for that truck cost me?
Old May 10, 2009 | 01:43 PM
Pop the diff cover and take a look inside before condemning the diff. Typically, problems with the diff are not just in reverse.
cruukedeye
Jun 4, 2011 06:49 PM
02chevyblaze
Dec 1, 2010 11:06 PM
BaLListic_Evo
Jun 4, 2010 03:38 PM
Litehwk356
Mar 9, 2010 09:33 PM
nate7493
Sep 9, 2009 03:37 PM
