85 2.8L Blazer Not Starting
Old Dec 22, 2009 | 11:12 PM
thethingsidoforgirls's Avatar
thethingsidoforgirls is on a distinguished road
Default 85 2.8L Blazer Not Starting
Hello All,
Assuming my username explains one problem, I'll get right to the other.
The Blazer she left in my yard isn't getting spark.
Both the rotor and distributor cap looked awful so I replaced them.
My OHM Meter fuse is bad but I was able to read 12V across the Ignition Coil (Secondary terminal~coil wire-->Distributor) with key in *ON position and then upon startup voltage falls to 00.0V.
My question is this: Does the 12V across the Coil mean the coil is ok?
If so, where in this heap should I look next? ECM? Distributor?
More importantly, what does the nil voltage reading mean?
Aside from fixing my OHM meter, any neat ways to track this problem down would be helpful.
Thanks,
Sam
stschuyler25
Nov 21, 2010 09:34 AM
cgrett
Nov 15, 2010 09:08 PM
Sprocket
Mar 20, 2008 09:39 PM
chrisoaf
Oct 1, 2006 01:22 AM
Im_Bryan
Mar 29, 2005 01:20 PM
