85 s10 blazer lean and white smoke
cat converter is gone! ftw! cut it out and welded in a pipe...not the problem tho, but i wish it was. its the carburetor most likely not getting fuel thru carb (well very little), i have a new one getting here tomorrow. im keeping my fingers crossed..
Ive replaced the cap, rotor, plugs, fuel filter, carb, fuel pump, water pump. every time it gets up to operating temperature, it stalls out Unless you have your foot on the gas and the idle high, it will stall out every time. Does not
do it when its cold..it should run great and it does for about 10 minutes, and then it stalls when i try to give it any gas. unless i take it out of gear and get the rpms high and ride the clutch but it has no power it barley wants to push the truck, but idles like a dream. and once again when its cold it acts like nothing is wrong.
IDsteel
04-08-2015 03:21 PM
Chochi
06-06-2009 11:19 PM
