87 blazer rapare questions? with pics
Old Dec 16, 2010 | 12:22 AM
J0386's Avatar
J0386 is on a distinguished road
Default 87 blazer rapare questions? with pics
Ok I just got an 87 blazer sofar so good but found a few things i need some info on the first is the door hinge on the driver side is kinda worn out how would i go about replacing it? and i found some vacuum lines that look broke coming from behind the engine dont know if they are ventilation hoses or what but cant see where they might have came off of heres some pics of what im talking about
Old Dec 16, 2010 | 07:16 PM
burning_soul07's Avatar
burning_soul07 is on a distinguished road
First off you need to get us some info on your vehiecle, like a signature. We need to know engine year miles and anything else, like 4x4 or not. Luckily 4 you I got the same year same engine, so I know what your pics are looking at.
In pics # 2 and 3, the 2 lines are, 1 is a vent from the transfer case and tranny, spliced together down where you cant see, and, 2 the other goes to the 4wd actuator by the battery, both of those lines are CUT. If you look at the actuator on the front (closest to the battery) on the right side of it there should be a nipple there that would take one of the 2 hoses that is there.
And the door hinge you could either find some hinges at a u pull it or I am sure if you check some auto parts stores you could find some new replacements. Bolt and go parts.
Old Dec 16, 2010 | 11:33 PM
J0386's Avatar
Im not sure its the lines to the 4wd actuator cuse it seems to be all hooked up one is ran to the 4wd actuator that hooks under it and the other has some kinda plug in it hooked to the passanger finder..
Old Dec 17, 2010 | 02:58 AM
Check this link....
http://www.s10forum.com/forum/f220/t...thread-327817/
It follows the vacuum diagram I am talking about on a S10 Blazer frame.
Old Dec 17, 2010 | 10:59 PM
J0386's Avatar
Thanks for that link im sure the vacuum lines are for that vacuum Orb so ill probably pick one of them up tomorrow but now i found a new problem it seems that its stuck in 4hi cuse with the 4x4 shifter on 2wd the front wheel lights on the 4x4 indicator stay on and the dot by the 2wd dosent light but if i put it in 4hi neutral or 4lo the lights all work and i noticed that the 4wd actuator stays sucked in and wont release with the shifter on 2wd unless i unhook the vacuum line but then not even the dot by 2wd lights up..
*****EDIT****
Ok its all fixed it was the vacuum switch on the t-case, it was stuck so now all the vacuum lines for the trans and t-case are all hooked up and working fine and so is the 4x4 and 4x4 shifter lights thanks for all ur help burning_soul07
PaulO2288
Oct 26, 2009 12:12 PM
dew88
Jul 13, 2009 04:30 PM
jdpilot
May 28, 2009 07:12 AM
stevenf
Jun 21, 2008 09:08 AM
vankuen
Sep 22, 2007 05:26 PM
