87 starting issues
Old Aug 9, 2016 | 09:31 AM
Brookhaven's Avatar
Brookhaven is on a distinguished road
Default 87 starting issues
Ok. I installed a new fuel pump on 87 Blazer and since doing so, I now have hard start issues. I now have to turn it over 4-5 times before it will eventually start. This happens hot or cold. It almost seems as though the fuel line is losing pressure allowing the fuel to drain back into the tank. Is this possible? I don't know where to start.....should I replace the entire fuel line?????? Thank you in advance for any suggestions.
J T
Old Aug 15, 2016 | 01:21 PM
willyP's Avatar
willyP is on a distinguished road
check your fuel pressure regulator. if that's not working correctly the fuel can run back to the tank when you shut the vehicle off.
Old Aug 16, 2016 | 12:13 PM
chris015's Avatar
The fuel pump has a check valve in it. if it goes bad the pressure will leak down completely. only fix is replace the pump.
cgrett
Nov 15, 2010 09:08 PM
tadder52
Dec 18, 2009 09:38 PM
Sprocket
Mar 20, 2008 09:39 PM
dragonsdeath
Oct 7, 2006 01:08 AM
BuddaBoy
Engine & Internal
Dec 7, 2005 03:36 PM
