Starting issues
Old Nov 30, 2005 | 10:04 PM
BuddaBoy's Avatar
BuddaBoy is an unknown quantity at this point
Default Starting issues
I am working on a 1989 4.3 l with the 220 EFI.
my friend was driving one day and then it just died...ever since then it won't start.
The fuel pump is new, only a few days old,filter the same.When I crank it only drops of gas come out or none at all, the relay is working also ( new ).Treid putting gas into the the throttle body and it turns and starts but then dies..theose bloody injectors arn't shooting any fuel.
Any ideas would be appreciated
Sorry for this late comment, but, hi to you all
Old Dec 3, 2005 | 10:13 AM
BuddaBoy's Avatar
Default RE: Starting issues
So I guess nobaody has any ideas to this problem
Old Dec 4, 2005 | 02:42 AM
drkmelvin's Avatar
drkmelvin is an unknown quantity at this point
I would ask Swartlkk...he is the shiznit with FI probs
Old Dec 5, 2005 | 08:04 AM
So you're the reason why I keep getting PMs, drkmelvin...!!! ERRGH...
Anyway, as I have stated in my PM reply, possibilities include a kinked fuel line, bad fuel pressure regulator, bad fuel pump, and/or a cracked fuel pickup tube. Other than that, I don't have a clue.
*NO SMOKING FOR THE REMAINDER OF MY TROUBLE SHOOTING STEPS!!!*
I'd inspect the fuel lines. If they look good, then take the fuel filter out and direct the line into a bucket and energize the fuel pump to see if you get fuel. If you don't, your problem lies in the tank and you have narrowed down your issue to either the fuel pump itself or the fuel pickup tube, but I'm not sure if you're pump uses a plastic fuel pickup tube or not.
I guess... Well, you said that you only get drops of fuel out at your injection system (btw, what system are you running on it?)... Have you checked fuel pressure? Like, will it come up to pressure if you give it enough time. If it will, then your FPR (fuel pressure regulator) is still good. Then you have a flow restriction somewhere in the system between the filter and the fuel pressure test port.
Old Dec 6, 2005 | 04:24 PM
chevylane2003's Avatar
chevylane2003 is an unknown quantity at this point
just fixxed that on mine. take the ignition control module and have it tested also check the two ecm fuses my control module was dead and come to find out it controls more then just the timing. controls the injection, air fuel as well. a new one costs around 30-35 bucks.
Old Dec 7, 2005 | 04:39 AM
jimmy91444's Avatar
jimmy91444 is an unknown quantity at this point
same thing happened to me ,2 day's after changing my gas tank.When i put my tank back on, i forgot to tighttend the ground cable.
Old Dec 7, 2005 | 03:36 PM
Hanr3's Avatar
Hahahahaha.
Seems to be a trend. After I replaced my fuel pump and fuel filter my ignition control modual also died.
cgrett
Nov 15, 2010 09:08 PM
jakeclope
Dec 18, 2009 10:19 PM
tadder52
Dec 18, 2009 09:38 PM
Sprocket
Mar 20, 2008 09:39 PM
dragonsdeath
Oct 7, 2006 01:08 AM
