88 4.3 Fuel and spark, no start
Old Jun 29, 2011 | 02:28 PM
88blaz4.3's Avatar
88blaz4.3 is on a distinguished road
Default 88 4.3 Fuel and spark, no start
Ive been lurking this forum for a while now and my truck died so I thought I would post. I was driving at 50 MPH at it just completely cut out and died. It will turn over and act like it wants to start but it just wont go. I have spark, although I'm not sure if its a really good spark or not. It also is getting gas, and I can hear the fuel pump prime. I sprayed some starting fluid in the throttle body yesterday with my gf trying to start it. It would sound like it was ready to pop and I would spray it and would get nothing. Im thinking it must not be a fuel issue? I have replaced coil, icm check plugs and wires. Not sure what to do from here?
Old Jun 29, 2011 | 07:36 PM
ohsofly's Avatar
How are you checking spark?
Just cause you hear the pump doesnt mean you are getting fuel... You should check the pressure.
If it wont start on ether, then you should check the timing, even though in my experience if the timing is off it will backfire out the TB... You said you changed your ICM, did you pull your distributor out to do so? You may have put it in 180degrees out?
Old Jun 30, 2011 | 08:16 AM
88blaz4.3's Avatar
I need to buy a nice spark tester, but I pulled a wire, put a new plug on it and grounded it while someone cranked the motor. I want to check fuel pressure but there is no valve on there anywhere to hook it to and its all metal lines, where do people hook the fuel pressure tester to? And when I changed the ICM I only pulled the cap, everything was reinstalled correctly. Thing that confuses me is when I try to start with some starting fluid it does nothing, that makes me think its not a fuel problem. I donno
Old Aug 17, 2011 | 08:41 AM
88blaz4.3's Avatar
Update...
I had to replace the tank because it had a hole in it. I put in a new pump since I was already there. Also a new fuel filter. Check psi and Its at 11. Also bought a spark tester and it has good spark. This thing still will not start. Any more ideas, because Im getting very angry at this thing and its about to go to the scrapper
Old Aug 21, 2011 | 11:16 PM
just plain lucky's Avatar
just plain lucky is on a distinguished road
wow same issue just put in new fuel pump and filter new plugs wires cap and rotor and new cat... I am about to pull the plenum and go that direction with it see if the injectors are all working and what not let me know how your is comming I have had mine for three years with no major problems, its a very dependable car... please keep me in this loop at just plain lucky Thanks and good luck.
RolliE319
Apr 10, 2013 10:29 AM
armydad71
May 3, 2010 01:48 PM
85_blazer
Sep 30, 2009 06:59 AM
elgringo
Sep 27, 2009 11:53 PM
fast400
Aug 31, 2007 05:07 PM
