88 S10 Blazer
To answer your original question. Should be a matter of motor mounts, tranny mount, exhaust pipes, and puter. Teh 4.3L radiaotr willwork provided both engines are serp set-ups (verify the input and outputs of the rad matches the water pump). Swap the puter and wiring harness.
Your t-case should bolt up to the back of the tranny just fine. The only difference between the 2.8L 700R4 and the 4.3L 700R4 is the bolt patern on the bellhousing. You can take the inernals out of either and swap them into th other one. They are identical except for the case.
Dallas1970
Feb 22, 2019 05:05 PM
94BlazerGirl
Aug 28, 2014 06:14 PM
rfine67
Aug 13, 2011 01:04 PM
1994BlazerS10
Mar 3, 2010 08:52 AM
