88 S10 Blazer 4.3 TBI stumbles then dies
Old Mar 31, 2007 | 07:15 PM
hotbloodsx3's Avatar
hotbloodsx3 is an unknown quantity at this point
Default 88 S10 Blazer 4.3 TBI stumbles then dies
[sm=helpout.gif]Hi, Need some help please! I have a 88 S10 4.3 TBI 217k miles ([sm=smiley20.gif]proud to say) that starts after a couple of cranks, runs fine, then at idle change the engine surges then dies. Same thing if I was to rev the engine. The CHECK ENGINE light is not on, at lowest point of surge timing is retard. No trouble codes. Spark Plugs, wires, distributor cap, air filter & fuel filter all have been changed. I don't think it is a sensor because I would have got a code (right?). I'll be checking fuel pressure after I post this. Maybe fuel regulator or pump? Suggestions will be much appreciated.
Thanks!
Old Apr 1, 2007 | 05:15 AM
Chevy Lover's Avatar
Default RE: 88 S10 Blazer 4.3 TBI stumbles then dies
I would check the TPS and timings. It might be a good idea to check the IAC valve also.
Old Apr 1, 2007 | 05:44 AM
kakn's Avatar
kakn is an unknown quantity at this point
this may sound like a stupid question but is there gas in the tank? the only reason i ask is becuase my 91 started doing the same thing and my gas gauge said i had a 1/4 tank. aparently my gas gauge is wrong by a 1/4 tank i supose.
Old Apr 1, 2007 | 06:51 AM
Thanks for the reply,I'mstill: [sm=headbang.gif]. My timing is retard 15 degrees, and I thought about the IAC valve & others, but wouldn't they give me a trouble code with the diagnostic machine? Regarding the gas...go figure the rare time I do have a full tank, I may have to go playing in it. I tested the fuel pressure; with the key to acc position I hear the pump, the pressure goes up to 28 kpa then I hear a click & it drops to0. With it running it holds at about 35 kpa, but it still surges and dies.[sm=outcold.gif]Any more suggestions? This chick needs her ride back! Thanks!
Old Apr 2, 2007 | 12:38 AM
Hanr3's Avatar
Typically the only thing that wont trip a code is fuel related. Like fuel pressure.
TBI would be 9-13psi. CPI is 54-62psi. At least according to my Haynes book.
Do you still have a cat on the exhuast system? When was the last time it was changed? A plugged cat will cause an engine to die, especially at higher rpms.
Old Apr 2, 2007 | 07:08 AM
Thanks for the reply, No cat just dual flowmasters. I'm going to change the fuel pump tomorrow. In another forum I read a thread that sounded very similiar and the mechanic said to change the fuel pump & remove the accumulatorthat's above the pump & replace it with a longer hose.Anyone else heard of this?
myZR2blazer
26
Nov 7, 2014 01:19 PM
kylehutch3
Feb 26, 2013 04:32 PM
ddog800
14
Feb 16, 2011 03:01 PM
rc1626
Jan 24, 2009 08:50 PM
slotmachine
Oct 14, 2007 12:02 PM
