89 s10 blazer dies then starts moments later
Old Feb 26, 2013 | 01:58 PM
kylehutch3's Avatar
kylehutch3 is on a distinguished road
Default 89 s10 blazer dies then starts moments later
my 89 s10 blazer recntly started aving an issue. the check engine lght will come on and then sometimes it will die and not want to start up agin. ireplaced the fuel filter and the coil.i cant seamto figure ut whats wrong. anyone had this issue? its the 4.3 automatic. please help. im not very car savvy this is my first time trying to fix the problem rather then sell the car because i love my blazer
Old Feb 26, 2013 | 02:06 PM
What is the 8th character of the VIN?
Old Feb 26, 2013 | 02:08 PM
kylehutch3's Avatar
eighth character is Z
Old Feb 26, 2013 | 02:11 PM
Have you checked the fuel pressure?
Old Feb 26, 2013 | 02:13 PM
kylehutch3's Avatar
no not yet i dont have a fuel pressure gauge to do so with
Old Feb 26, 2013 | 02:24 PM
Most auto parts stores rent/sell/loan pressure testers. Make sure it specifically says "GM TBI" systems. The air cleaner must be removed to access the test port on the throttle body and it usually has a black plastic cap on it, (the fitting looks much like a tire valve stem). Remove the cap and attach the pressure tester. With the engine at idle, pressure must be 9psi to 13psi.
Old Feb 26, 2013 | 02:32 PM
kylehutch3's Avatar
isnt there a pressure tester that can be connected where the fuel filter is? thats what my brother was tellin me.
Old Feb 26, 2013 | 02:46 PM
You can check it there, but it requires more fooling around to adapt the tester to the lines.
Old Feb 26, 2013 | 02:52 PM
kylehutch3's Avatar
ok thanks for your help im waiting on some money right now to go rent the tester. i will post again if its not that. thank you. oh, whats the 8th letter of my vin got to do with anything? jw
Old Feb 26, 2013 | 03:01 PM
kylehutch3's Avatar
and is there any way that you could post a picture of what im looking for to hook the tester up to? it would help me out alot
