88 s10 blazer bad idle please help
Old Dec 20, 2009 | 07:26 PM
1987blazers15's Avatar
1987blazers15 is on a distinguished road
Default 88 s10 blazer bad idle please help
Hello i have an 88 blazer with a 4.3L i have been having issues with it for about 2 weeks. i will be driving then all of a sudden it will lose power and wont go anwhere the more i push the gas the more it bogs then it will kick in again and fly. i have drained all gas and new filter incase of water. any suggestions? it will happen when ever it wants to. thanks in advance
Old Dec 21, 2009 | 07:10 PM
88 rusty but trusty's Avatar
88 rusty but trusty is on a distinguished road
Had the same problem, changed out the iac 2 weeks ago and no problems since. Only $25 for part and 10 mins to change
Old Dec 21, 2009 | 07:24 PM
mr.vls's Avatar
Idle Air Control, O2 Sensor.
Old Dec 22, 2009 | 04:46 PM
hey i was told that i need a fuel pressure regulator kit? is this common?
Old Dec 22, 2009 | 07:33 PM
mr.vls's Avatar
If this is a TBI the answer is yes. The kit is not much more the a few gaskets and a spring and a diagphram. This controls your fuel pressure at the TBI. You need around 11 psi for a TBI engine to run smooth. I installed an adjustable regulator with a fuel pressure gauge installed on the fuel inlet. This way I can always check the fuel pressure with a quick look under the hood.
Old Jan 13, 2010 | 02:04 AM
crashhole's Avatar
crashhole is on a distinguished road
mr vls, could you provide the parts needed to install a pressure gauge?
Maybe a picture would help also. Thanks.
Old Jan 13, 2010 | 05:54 AM
mr.vls's Avatar
I purchased my adjustable fuel pressure regulator, Injector Spacer, Fuel Pressure gage, Tee and inlet fittings from CFM-tech. Here is the link:
http://marine-performance-parts.com/index.aspx
jmatt07
Jan 26, 2011 09:44 PM
matt92
Nov 27, 2010 06:56 PM
gunner0352
Feb 20, 2010 11:51 PM
rogggg1020
Nov 11, 2008 08:05 AM
