Bad idle and acceleration, need help.
Old Nov 26, 2010 | 04:47 PM
matt92's Avatar
matt92 is on a distinguished road
Default Bad idle and acceleration, need help.
This just started happening yesterday.
At first, it was only when i was accelerating, and it would hesitate pretty bad.
But today, It idles horrible, and accelerates even worse.
I had the codes checked, and i got coolant temperature, and secondary air injection.
Do these affect idle? and how hard is it to fix this??
I bought a thermostat too.
Old Nov 26, 2010 | 06:12 PM
01vortec's Avatar
01vortec is an unknown quantity at this point
change the coolant temp sensor. secondary air injection will not affect how the motor runs.
Old Nov 26, 2010 | 06:35 PM
matt92's Avatar
alright, wheres it at? and how do i replace it?
Old Nov 26, 2010 | 11:47 PM
matt92's Avatar
bbuummpp
Old Nov 27, 2010 | 06:12 PM
webstar1271's Avatar
webstar1271 is on a distinguished road
also try lucas "a real fuel system cleaner. and or "seafoam" it.
Old Nov 27, 2010 | 06:56 PM
You know... Instead of uselessly bumping your post you could have tried the nifty search feature... "Coolant+temperature+sensor+location" seems logical... Near the bottom of that search page is this thread:
coolant temperature sensor
But what were the codes your received. You may actually want to diagnose the problem before just replacing components.
On your idle issue, a few DIY preventative maintenance items may be in order. Such as cleaning your MAF sensor, throttle body (including the IAC sensor), and EGR valve; much of which is covered in various threads found in the Tech Article (DIY) section.
tdbone1
Dec 20, 2012 09:40 AM
JHSmith5228
15
May 4, 2012 01:28 AM
klote82
Apr 27, 2012 08:22 PM
coltc
Feb 27, 2009 09:00 PM
Blazer4U
Aug 18, 2008 07:23 PM
