'88 s10 water TEMP gauge reads zero
Old Jul 13, 2009 | 10:29 AM
jimminiquick's Avatar
jimminiquick is on a distinguished road
Default '88 s10 water TEMP gauge reads zero
1988 S10 blazer V6 4.3L
Im having trouble diagnosing and fixing a problem with my temp gauge reading zero.
I have changed the sender, which resulted in an immediate reading of MAX.
When the car's ignition is in AUX there is voltage going to the unit, but no temp reading, BUT when the car is turned on, no voltage is read going to the sending unit.
Any ideas?
Old Jul 13, 2009 | 12:47 PM
bandidolenny's Avatar
When you installed the new sender unit you didn't wrap it in teflon tape did you?.. it needs a good ground.
Do all of the other gauges in the cluster work? I would check to make sure that you have a good ground to the gauge cluster.
Old Jul 13, 2009 | 11:43 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
quick question. i changed the coolant temp sensor on my 86 s10 blazer with the 2.8L V6 and when i changed it i put teflon tape on it would that affect anything?
Old Jul 14, 2009 | 09:27 AM
no, teflon tape was not used. i wanted to make sure i had a good ground.
if you have put teflon tape on the sensor unit, and it is working, it should be fine. i just wanted to rule out the possibility of having a bad ground
zakm0n
Jan 9, 2011 07:31 PM
boscoedoodle
Nov 24, 2009 10:56 PM
chipo022
Jun 1, 2009 03:12 PM
blazerguy22
Dec 12, 2008 07:59 PM
Mulisha
Mar 24, 2008 09:14 PM
