89 4.3 pushing antifreeze out resivor tank cap.
Old Feb 21, 2011 | 03:33 PM
rdhoping72's Avatar
rdhoping72 is on a distinguished road
Default 89 4.3 pushing antifreeze out resivor tank cap.
does anyone know y? doesnt overheat..had no problems..
Old Feb 22, 2011 | 09:39 PM
burning_soul07's Avatar
burning_soul07 is on a distinguished road
Maybe the cap on the radiator is faulty and is allowing the pressurizing antifreeze to escape into the overflow tank then out the top .
Old Feb 23, 2011 | 10:48 AM
rdhoping72's Avatar
I can try a new cap,,it seems to do it worse when the resivor is full like it should be..Thanks
Old Feb 23, 2011 | 11:27 AM
JustJerry's Avatar
JustJerry is on a distinguished road
How full do you fill the overflow tank? If you overfill & or fill it plumb to the top, it will overflow.
Old Feb 23, 2011 | 01:36 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
its sounding like a head gasket is on its way out. cooling systems run 15psi max, if you have the samllest leak from the cumbuston chamber to the water jackets in the block then your pressureizing the cooling system to maybe 50-150psi, which the cap will regulate the pressure and dump the excess in the overflow bottle. the leak may not be big enough yet to cause a overheating concern, but it could evuentually.
Old Feb 27, 2011 | 02:58 PM
rdhoping72's Avatar
I only fill it to the full-hot line..and that sucks if it's a head gasket going..thanks for the info..
Old Feb 27, 2011 | 06:44 PM
JustJerry's Avatar
Hated to ask that question, but there be some that thinks your to fill the radiator overflow plumb full. If that was the problem it sure would be much easier that a head gasket or something worse. Sorry to say its kind of sounding like a head gasket or worse.
Dan 128
Jun 8, 2011 10:11 PM
classklown90
Jun 13, 2009 07:20 AM
Chochi
Jun 6, 2009 11:19 PM
ranger0001
Nov 2, 2007 09:58 AM
v8vairman
Apr 12, 2006 01:43 PM
