89 blazer 4.3 wont start
Old Feb 17, 2011 | 09:20 PM
alcortez's Avatar
alcortez is on a distinguished road
Default 89 blazer 4.3 wont start
i have a lil problem my blazer wont start and has been sitting for a long time but when i spray starter fluid on the tbi it starts perfect and when driving it drives perfect with out the air filter on. once i put the air filter on when the truck is running it dies right away. any suggestions or help will be much appreciated
Old Feb 18, 2011 | 06:52 AM
When was the last time the air filter was replaced? How does it look? Do you have proper fuel pressure (9-10psi)?
Old Feb 18, 2011 | 10:27 AM
alcortez's Avatar
the air filter is like 2 or 3 months old and how do i check for fuel pressure? i had a fuel pump put in like 2 years ago but since then it has been sitting
Old Feb 18, 2011 | 11:18 AM
To test fuel pressure on a TBI motor, you need to install a 't' fitting on the feed (larger) line at the back of the TBI unit that will allow you to use a fuel pressure gauge. Most of the >$50 fuel pressure gauge kits comes with the 't' fitting in them or you can buy a fitting and a gauge together for less that you just leave installed.
dj00140
May 20, 2013 06:37 PM
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
jetsmy
Aug 1, 2008 10:10 PM
