89 gmc no power
89 gmc no power
hey guys i got a 89 gmc jimmy with 4.3 4x4. truck seems to idle good and it dont use any oil but it seems to run very weak kinda like im draging another truck behind it.. i hit the gas and there are no hesitation, it just feels like im trying to take off with my foot half on the break..any ideas on what to look for..so far i have changed plugs ,wires, run seafoam through gas and also pulled the tbi and made sure it was clean and replaced the tbi to intake gasket..thanks for any advice
RE: 89 gmc no power
anyone
RE: 89 gmc no power
Please have patience and give folks some time. Thanks.
RE: 89 gmc no power
Is your e-brake stuck? I've had that happen to my 94 and ended up having to remove the brake and cable
RE: 89 gmc no power
well i thought that and i did check it..the ebrake ingages and disingages like it should but i will look again..thanks for the reply
RE: 89 gmc no power
Auto or standards trans, Might be getting slipping in the auto trans, If its auto try changing the fluid and add Lucas. Did wonders in my 86 S10 pickup
RE: 89 gmc no power
its a auto, i will defently check that out.. it seems to shift just fine but i will check it out..thanks
RE: 89 gmc no power
Mine shifted fine also, Just feels like a cat is pushing your car. I think the Lucas transmission fix was the only thing that ever worked as a fix in a Fluid lol
RE: 89 gmc no power
well since we are talking about the trans. this may not have nothing to do with it but i know its very hard to pull the shifter down into 4 wheel drive.. it will go but its hard to pull the shifter.. im very new to the 4x4 so could it be a fluid thing with that also
RE: 89 gmc no power
Make sure your transfer case is not in 4 high. Check all fluid levels including t-case and diffs for anything out of ordinary. You may have a trannyshop (more than one) test drive the vehicle and give you their opinion. Any check engine light activity? I know its older but maybe scan the computer for any codes. Catalytic converter clogged maybe? Bad gas? Did this just start one day or did it come on slowly?
