89 S10 Blazer 4.3 4X4 I cant find Speedo Cable
Old Nov 12, 2012 | 10:43 AM
RexCastle's Avatar
RexCastle is on a distinguished road
Default 89 S10 Blazer 4.3 4X4 I cant find Speedo Cable
I am trying to located where the speedo cable is located under the truck with no avail, does anyone have a photo?
Old Nov 12, 2012 | 11:35 AM
neo71665's Avatar
I think 89 still has cable drive if so:
comes out the drivers side of the t-case, runs under the drivers seat, up the firewall, into the firewall right beside the brake booster.
Old Nov 12, 2012 | 12:41 PM
Diaita's Avatar
tailhousing of the transfer case(near the rear driveshaft)
Old Nov 12, 2012 | 02:48 PM
Blazin_Jason's Avatar
My 89's are electronic speedo.
Old Nov 12, 2012 | 06:08 PM
neo71665's Avatar
Thanks for clearing that up. I was thinking 90 was the swap year. Honestly 89 is one of the 3 85-93 I haven't owned.....yet.
Old Nov 12, 2012 | 07:10 PM
RexCastle's Avatar
well the problem i am having is speedo and odo are not working but everyhting else in the cluster is. also i have the old style gauges like the 88's not the newer digital
Old Nov 12, 2012 | 08:03 PM
chris015's Avatar
is possibly your oil gauge funky and your brake light on? Mine did all that and speedo when my gauge fuse fuse was blown. turned out to be a short in the harness behind the distributor.
Old Nov 12, 2012 | 08:53 PM
RexCastle's Avatar
Oil gauge is fine and no lights on that shouldn't be. I found some old records in the glove box dated back to 2010 and it had the same milage on the receipt that the odo currently reads, so i know the problem has been there at-least 2 years at a min
Old Nov 12, 2012 | 09:00 PM
neo71665's Avatar
Most likely the VSS bad.
And they called analog gauges.
Old Nov 12, 2012 | 09:29 PM
RexCastle's Avatar
Is there only 1?
