'91 4.3 idle rough at stop light
Old Apr 2, 2007 | 01:45 PM
ktfr4's Avatar
ktfr4 is an unknown quantity at this point
Default '91 4.3 idle rough at stop light
After replacing distributor cap, rotor, plugs, wires and PCV (I’ve done this regularly since I purchased the car new with no adverse results) – it now idles rough at operating temp stopped red light. Smog failed HC (130 with 124 being the upper limit). I checked all vacuum hoses, triple checked plug wire routing, checked new wire resistances, and finally reinstalled the original wires – NFG. Took it to shop -no error codes, they recommended replacing the EGR valve. I did this as well with the no change. Is there anyone who has been here before?
Old Apr 4, 2007 | 04:06 AM
88blackzcand95blazer's Avatar
88blackzcand95blazer is an unknown quantity at this point
Default RE: '91 4.3 idle rough at stop light
cat clogged?
Old Apr 4, 2007 | 08:59 PM
Mbastet99's Avatar
Mbastet99 is an unknown quantity at this point
IAC? Air filter?
Old Apr 5, 2007 | 04:07 AM
Chevy Lover's Avatar
Plug gap, vacuum leak, if it was a missfire your HC would be really high. Sounds like a minor vacuum leak with the rough idle. Try lightly tapping the EGR when it's idling rough to see if it smooths out.
What's your idle RPM? If you can raise the idle 50-100 RPM, that might cure the HC problem.
What's the CO reading? And what's the allowable CO
Other usefull info would be engine, year, model, fuel type etc..
Old Apr 8, 2007 | 11:14 PM
ktfr4's Avatar
Plugs were replaced with Champion 4018 “Truck Plug” – gapped of .035. I have sprayed water and the shop I took it to sprayed carb cleaner around vacuum hoses at the TBI. The mechanic did tap on the EGR and thought it made a difference - hence changing EGR.
I do not know the RPM.
Here is the smog report:
15 MPH - HC – MAX 124, MEAS 130….CO – MAX .75, MEAS .17
25 MPH – HC – MAX 104, MEAS 65….CO – MAX .95, MEAS .36
Engine: 4.3 TBI “Z” – 1991 S10 2WD Blazer – unleaded…..
schapm5926
Aug 30, 2014 11:28 AM
dannyb91979
Jul 16, 2013 06:08 PM
clicheche
Mar 24, 2013 09:17 AM
nhguy261
Dec 30, 2010 01:41 PM
c10jm
Aug 12, 2008 05:34 PM
