91 blazer stalls after long idle
Old Feb 4, 2009 | 03:59 PM
danrnelson7@hotmail.'s Avatar
danrnelson7@hotmail. is an unknown quantity at this point
Default 91 blazer stalls after long idle
I recently moved from Calif to Michigan my blazer runs fine, but after a long idle it coughs and hesitates when accelerating. Runs fine unless I sit at idle after warmed up i.e. drive thru at McDonalds, bank ect. So where do I start?
Old Feb 4, 2009 | 06:44 PM
rdhack's Avatar
rdhack is an unknown quantity at this point
Default RE: 91 blazer stalls after long idle
Possibly exhaust system, or EGR system. Mine codes the o2 sensor running lean after a long idle. Do you get any codes?
Old Feb 4, 2009 | 10:58 PM
Sounds as though it is loading up with fuel... Have you checked for a fuel leak around the injectors (this is a TBI motor correct?)? How about a vacuum leak at the base of the throttle body? Possibly a partially clogged IAC passage/valve (I think the TBI motors had an IAC valve anyway)?
Old Feb 16, 2009 | 08:32 PM
Blazercrazy's Avatar
Blazercrazy is an unknown quantity at this point
I'll throw 20 bucks on the timing being off a tad, Had the same problem with my 86 s10 pickup. Get a mechanic to throw a timing light on it
BlazerGriffin
Jun 27, 2010 11:56 PM
cide
May 4, 2009 02:23 PM
gnpower
15
Apr 20, 2009 12:48 AM
richard5294589
Dec 23, 2006 01:03 AM
see119
Aug 30, 2005 02:00 PM
