'91 S10 4.3L runs rough
Old May 27, 2009 | 07:33 PM
NC Driver's Avatar
NC Driver is on a distinguished road
Default '91 S10 4.3L runs rough
I have a '91 S10 Blazer with the 4.3L engine. Sometimes when starting it acts like it is running very rich and stumbles. If I rev the engine a couple times, or drive briefly in low gear and take my foot off the accelerator it will settle down and run well.
It also does this rough idle if I drive at high throttle for a while, then stop.
I have replaced the PCV valve (although the old one did not look bad).
Any other ideas? Clean the MAF? Others?
The car gets around 17 mpg with mixed driving.
Thanks in advance.
Old May 27, 2009 | 07:55 PM
You do not have a MAF sensor so that is out.
I would clean the EGR valve. If this is leaking past, it can cause rough idle and an overly rich condition.
Old May 28, 2009 | 01:26 PM
NC Driver's Avatar
Thanks. I will check it out.
Mark
Old May 28, 2009 | 11:39 PM
ClueMeIn1989's Avatar
ClueMeIn1989 is on a distinguished road
Where exaclty is the EGR valve on the first gen's ? Mines a '94, Im just curious.
Old May 28, 2009 | 11:43 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
if you run a quick search you should find your answer i know its been discused before and i beleive someone posted a picture of the EGR location also.
coffen
Dec 25, 2013 09:09 PM
bam_9_9_9
49
Dec 30, 2012 08:42 PM
zakm0n
Jan 10, 2011 11:42 AM
sword2269
Sep 9, 2009 07:33 PM
c10jm
Aug 12, 2008 05:34 PM
