91 S10 won't run
Old Apr 30, 2011 | 05:19 PM
grumpyd's Avatar
grumpyd is on a distinguished road
Default 91 S10 won't run
I have a 91 S10 4.3 that wont stay running. It will start when I spray a little gas in the tbi but won't stay running unless I keep pumping the throttle. I changed the gas in it, put a new fuel filter on it and put a tune up kit in the tbi. Still does the same thing. Thanks for the help.
Old Apr 30, 2011 | 07:36 PM
chris015's Avatar
Sounds like low fuel pressure. check pressure,should be 10-13 psi. May end up being pump. If it is,PLEASE buy only ac delco or delphi brand parts..I learned my lesson.
Old May 1, 2011 | 07:00 AM
grumpyd's Avatar
How can I check the fuel pressure
Old May 2, 2011 | 01:01 AM
chadillac85's Avatar
chadillac85 is on a distinguished road
there will be a larger shrader valve on the fuel lines goinig into rear of throttle body
Old May 2, 2011 | 05:02 PM
grumpyd's Avatar
Ok, I have fuel pressure but still wont run unless I pump the crap out of it.
Could injectors be bad? How can you tell? They squirt when its running and I am pumping it but that is all they dont squirt when Im not working the throttle.
HELP!!!
Old May 3, 2011 | 03:38 PM
when the injector sprays is it in a cone form? if not then ud have dirty or bad injector.
Old May 5, 2011 | 06:27 PM
grumpyd's Avatar
FYI it was the little fuel line on the pump
Old May 5, 2011 | 06:30 PM
xgiovannix12's Avatar
starts now?
Old May 6, 2011 | 08:17 AM
grumpyd's Avatar
starts and purrs like a kitten
thanks for everyones help!!
Old May 8, 2011 | 12:34 AM
good to hear! enjoy yours like we all do
